Thread: Idle Problem
Old 03-14-2011, 07:44 PM   #2
Conga1991
Conga1991 is on a distinguished road
So I just remembered there was a screw for the throttle body, turned the car on adjusted it and it runs fine now, but whenever I rev it up it stays at a high rpm until I have to pull the it so it will idle lower. The Tach doesnt work, so Im unsure what my rpms are but I have an SAFC-1 and will install that later tonight. Just need to fix the oil leak which is in the spark plug galley and flows behind the block onto the transmission. replace those bolts and Im good to go... hopefully.
Conga1991 is offline   Reply With Quote
