BC's after tax were about 1100, installed them myself, they come with pre-load options by model also but the pre-loads are fairly conservative. After tuning the spring rates and ride height, the BC's are performing on par with my TEIN SS setup on my 1990 targa supra. I use these for a drift setup so they are pretty much trying to be broken atleast twice a month, had these for about 6 months now and not even the end links are showing wear, good sign for those interested in something that won't break after taking it around the track a few times. Downside of the BC's, too many ranges of adjustability to actually feel like each click is doing something, also very stiff have to turn down to almost two clicks away from max soft to get a ride that doesn't make you want to drive fast everywhere. Also if you do get these make sure they are 2010 production or higher, the pre 2010 BC's were made with lower quality metal's and are not nearly as robust as the improved coilovers. Something that won't be mentioned to you when you buy, so make sure you point it out.
