Mine was dripping from the tranny too. Changed out the rear main gaskets, the front gaskets, the valve cover gasket, etc. Then they used a dye and with the valve cover off discovered the leak. The 7mge and 7mgte have a problem with their head gaskets. After an overhaul and a rebuilt head, mine does not leak at all.
Not sure how mine found its way there but it did.
