Well if it is the same wheel but only narrower then all you need to do is know the offset of the 8.5 and measure off it to see where the 10 will sit. But as far weight goes on the wheel it affects gas milage, ride quality, braking and steering feel. But if you are just after the look then who cares. I just thought you might not want to lose out to a minivan off the line.
