Also, If the oil pump is to blame here, Would an OEM replacement good, or are there aftermarket, more efficient solution.
Intuitionally I would believe that the OEM oil pump would be fine, considering that the 7m is meant to be a high volume, low pressure engine.
88 Supra Tegra 7M-GTE Manual
Seattle, Washington (Granite Falls)
