Originally Posted by El_supracabra
Are you sure it's not grounded to the chassis? Where specifically does it mount to the engine? Does it go on a tranny bolt? The block? The plenum? Please be more specific. Thanks!
It goes under the intake manifold to the block. Right behind the alternator. It is a 12mm bolt and it is grounded by itself!
Sounds like a bad starter man!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
