Old 03-17-2011, 02:19 AM   #12
El_supracabra
El_supracabra is on a distinguished road
Oh and yes I did use a new clutch it was Autozone brand, I used to work there and I've never seen one of there clutches come back. So I figured it was as good as any. The only prob I had was that the bolt holes in the pressure plate didn't line up with the boltholes in the new AM flywheel. I just blamed it on craptastic aftermarket compatibility and drilled new holes in the PXplate. Seemed to bolt up great after that.
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
