Old 03-17-2011, 02:27 AM   #13
Travis89Turbo
Travis89Turbo's Avatar
Start with the easy stuff first. Pull the other two plugs and check in the cylinders for fuel (or anti freeze, but that's un likely), then try rotating engine with by rachet, re check timing, recheck dist is installed properly. Double check plug wire routing. then if no more ideas pull trans. But I doubt anything is goin on in there. Which is quite the job with engine in!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
