Old 03-17-2011, 06:12 AM   #14
El_supracabra
El_supracabra is on a distinguished road
Ok I was about to write a hateful email to CBhaus (regarding the flywheel because I had to drill holes in the pressure plate in order for it to bolt up and i was suspecting that it was causing my "lock up" problems)...
....when i noticed that i had ordered the flywheel for *TURBO ONLY*!!! WTF how did i miss the HUGE ASTERISKS that said *TURBO ONLY* ......sigh....well, i think i found the problem guys.....strangely, they LOOKED identical! AND they have the same number of teeth.
So what is the difference???? Do you guys think this is DEF the prob?
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
