Old 03-17-2011, 11:29 AM   #17
907mge
907mge's Avatar
All you have to do is pull out each plug and clean the threads. Then put enough rtv on the threads so it pushes out the top as you screw it back in creating a nice seal. Like the with the oil pan there is no need to really use a gasket. But if want a washer you can search for the type used for an oil drain plug. But the rtv way does work and will be clean if you do it right.
