Originally Posted by Supra_Freak_7m
Would it having the wrong fluid in it be enough to make it not work?
Yes. It is
Drain refill with proper fluid. And hope seals did not get damaged. The ps manufacture said to use atf for a reason. All fluids have different detergents (if any), lubrication capabilitys, compressability at diff. Temp ranges. And can even vary from the base oil such a mineral based or petrol, which will determine what material the seals are made out of. So yes the type of fluid they say to use should ONLY BE USED!
Mine was doin the similar thing with the correct fluid. I added some BARS powersteering fluid additive and it took care of it.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
