Thread: storing supra
Old 09-28-2005, 09:24 PM   #2
joel w
joel w's Avatar
Cool
minisota gets really cold right? storing it indoors or outside? id definatly check the antifreeze to make sure it is strong enough to prevent freezing at sub zero temps and or drain some out to give the coolant room to expand if it does beguin to freeze. 120v block heaters are really nice too. always toasty inside on startup if i park my rig for a long time i like to put it on stands to get the tires off the ground so the tires dont get flatspots in them. car covers are nice..visor sunscreens work. they make packets of some chemical that absorbs moisture (drys the air) i think its called for the interior if wet there to keep mildew out. plus all that you mentioned earlier should be good 2 go.
