In the garage awaiting parts. Replaced the entire exhaust with a Toyota stock system. My mechanic "you worry too much", we will use the old O2 sensor and the defusers off the old muffler. Well the O2 sensor was a screw in and some jerk welded on the defusers.
To make matters worse the cheap headers were welded into the front pipe in some of the worse welds I have ever seen. It is headed to recycle
Having no takers the one piece Ford drive shaft is going with them.
