Old 03-24-2011, 02:16 AM   #8
Sonyps307
That is because the wire that is for the ks is like a coax cable the main wire inside with a bigger ground outside wire casing so the wire doesn't get interference and the outer wire is grounded some where to the body. So to do the rewire you need small coax cable and solder the wire inside to the connetor and the outer casing wire to a ring lug then ground it. Took me and hour to remover the alt, solder and run the wire but I have a 7mge and it only has one KS.
