Old 03-24-2011, 09:57 PM   #22
El_supracabra
El_supracabra is on a distinguished road
Default IT LIVES! but....
well we fired it up today! It idles great, but when driving it, it does the EXACT same thing it did before. seemingly runs perfect until you hit exactly 4000 rpm then it starts spitting and stumbling.
I checked the timing w a light and its sitting at 10* advanced w/ a jumper on the diagnostic box.
But, I went through all this with it before the rebuild. It was sitting at 10* so i pulled the DIST and rotated it one tooth, put it back in and set it on 0* it dropped the idle so low it didnt want to run, so i adjusted the idle stop until it was idling around 1k rpm and it ran like crap when i drove it. I ohm'd the igniter/module/coil, throttle position sensor and the pick up coils. tested all of the VSV's and triple checked all wiring connections and vacuum lines. Everything seems to be perfect. could this be an ECU issue?
I think im going to post a new thread on this...
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
