Originally Posted by warmkop
Hi im from south africa bought a 94tt supra not many here this side need help making power out of my dream car. bougt a godspeed branch t4 need to know what exhaust housing wil work dont whant to much lag so 4000rpm is fine.busy with atermarket ecu,extra feul pump at least 23 psi with racing feul any comments welcome
Gosh...here's my advice (for now). Please slow down! One step at a time! Please do not get the fuel kit yet. Please do not invest in the aftermarket ecu yet. Let's come up with a plan that matches your horsepower level...if you want power at 4000 rpm, most likely the turbo will be small enough to work fine with the oem ecu. Also, any turbo with its max efficiency point at 23psi will be moderate sized at most. The Mkiv TT is an amazing, very upgradeable vehicle - and a lot of the stock parts are good to MUCH more than the oem rating. Ok?
Who is telling you to do all of these crazy things right now?
Where can I find specs on the "godspeed branch T4"?
