hey everyone.
im here to let you know im almost read to do the swap
im picking up my last parts tomorrow:
clutch fork
shifter
pedals
driveshaft
here is all the parts i have and need:
parts i already have:
w58
clutch master
slave cylinder
hard and soft lines
clutch kit
flywheel
flywheel bolts
clutch fork
drive shaft
shifter
and pedals
needed:
shift bushing
oil plug
if anything is missing please notify me, thanks :P
okay now on to my questions.
the pilot bushing?
where does it go? on the tsrm it shows a diagram of it going in between the flywheel and clutch disk.
but from talking to a mechanic and common sense, doesnt it go into the engine where the input shaft goes? then after that you put the flywheel, bolt it down and then the clutch assembly? am i mistaken? if so please correct me lol
the other question is what do i need to do EXACTLY to the neutral start switch?
thanks in advance
