Old 09-29-2005, 01:47 PM   #5
rnoswal
rnoswal's Avatar
If it was a broken line then the pedal wouldn't go to the floor because, depending on if it is the front or rear that is gone then the other will still work. Safety feature. Go to the parts store and buy one from them. They are fine and have a warranty. If you want to check to make sure there are no broken lines, just pour in some fluid and put it on dry pavement, step on the brakes a few times and if it is leaking you will see a wet spot on the ground. If it is the master cylinder, sometimes if you look under it, on the brake booster you will see a trail of wetness and bubbled up paint.
Russ
