Originally Posted by 89supra1990
89 supra 7mgte, car will not idle with the air flow meter hooked up but as soon as you unplug it it idles but its high, so does this mean the meter is bad??
any help would be appreciated
Thanks
Also check the vacuum line coming off the ps pump To the bottom of the accordion pipe. My old 7m did that when I would forget to hook that sneaky little thing up.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
