changing the waterpump
I just changed the water pump on the 7mgte.
Pretty straight forward procedure, only thing I would do differently next time around Is loosen the fan bolts with the belt still on, instead of using a leverage bar.
that and there is a air rail that runs directly in front of one of the bottom bolts for the pump. loosen it by the nut found were the metal connects into a vacuum hose on the right and move it out of the way. Makes it ezier when you're trying to put your new one on.
good luck.
