i think the master cylinder is shot...rnoswal said it right...the seals are shot too thats why its goin soft, pump it enough times and it will create a seal on its own..which is why the pedal got stiff again, rebuilding the master cylinder should fix the problem....but also check the lines...might have a small leak, or some air in teh lines
Now: Saving for an MKIV
Broken Rides:
