Thread: bbc
Old 03-31-2011, 10:58 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by TZimmz View Post
hmm i dont like how that sounds. but is there a way around it? example bigger injectors?
I don't know the Japanese-spec Mkiv that well, but I believe the HKS FCD together with a fuel controller (eg. An A'PEXi SAFC) would solve the problem. The FCD reduces the TPS sensor reading on a linear scale...couple that with the same linear increase in the fuel curve and you should have a solution.
Life begins at 30psi.
