wiring visually looks ok for #1 and #2 ECT Solendoids
Located the #1 and #2 Solenoid wires. Took hours online, they are not listed well.
They are Green - Black and Green - Yellow wires, that run nearly to the back of the transmission driver side and both go into a rubber insert into Trans. (There's one final wire that runs to very back which is something else).
Coming back from the AT, it meets a wire connector underneath the intake side of engine, and from there goes to ECT underneath glove box I gather. Wiring into ECT looks brand new, perfect, and all wires are still wrapped and look visually complete everywhere I can spot them. Will try to run the Ohm meter on them tomorrow to double check they are capable of carrying electrical current each way.
88 Supra 7M-GTE Turbo, TEMS, Targa stock
