Originally Posted by Travis89Turbo
You probably have leaking capacitors in your ecu. I kno you said u tried other but 95% of 1j ecu have leaking capacitors I had to replace mine not even a week ago.
The good thing is that it is easy to do if u kno how to solder. And about $2 for parts. Here is a link.
http://www.toymods.org.au/forums/sho...placement-info
i have tried a ecu i know is working perfect and its stil the same
