Originally Posted by cre
Do it after. I can't remember for sure but I believe one if not both of the bolts run into or through the bell housing.
my mechanic said after..
which makes sense cuz one of the brackets for the bellhousing is connect through the starter...
i got my clutch disk and my pressure plate on.. bolts on the PP and there alil less then hand tight..
ima torque em but before i do, is there anything i should be careful about? or do before i torque them?
(the alignment tool is still inside it BTW)
