well, some more updates. i got my hks MHG, Cam gears, cam cover, rad and a few misc parts ordered. i also picked up a billet rear spool from a buddy of mine (free, thanks john!) and all the misc sensors and parts i needed. the motor will be dropped in on two weeks. the sds efi is on the waiting list. the oil pan is waiting final measurements when the motor is in.
on the off side ( i know this isnt a 4x4 forum, but its kewl nonetheless.) i went to the local pull n save yard, and found a few dirt cheap goodies. first off, an 83 celica throttle cable that will work perfect for this particular swap (7mge in pickup/4runner). i also happened to find, a mint eaton m90 supercharger (the price was literally, amazing. $17 bux) i have since found an adapter plate from a company that allows simple adaptation to intercooler/intake piping. so, instead of my centrifugal from my firebird, ill use this one, especially since it has the bypass valve. i will mount it where the A/C pump was, after i get the engine broke in.
in addition to this, i found a York A/C pump, from an 80's volvo. i will use this for OBA (on board air) as it is a far superior design to any other a/c pump. this was also, $17. to give everyone an idea of how much i scored, these pieces were $250+ anywhere else. so i essentially saved $450 on some kick ass parts. i will rebuild and port the S/C, and refurbish the A/C compressor. ill have about $150 into that.
once again, sorry its for a 4x4, but the S/C find really lit a fire under my ass. basically, the m90 puts out 90 CFM/ 1.5L of air per revolution, so in .5 revolutions of the crank shaft, ill fill each cylinder completely (by mathematics.) this should push my motor, into around the 275-300 hp range, depending on tuning. i should be able to have the efi ordered by the beginning of june, and the truck running by the end of that, including dyno tuning. so get read for N/A numbers by mid june, and S/C numbers by mid july.
im also ditching the 6 puck ceramic clutch, and getting an exedy hd kit from my freind john (yet again, thanks!) to help with drive train shock and drivability.
after all this, anyone got prospectives on 1/4 mile times? im thinking around low 13's.
ill prolly be upgrading to a R series trans soon, as the W series will surely detonate not long after the supercharger add-on. its taking alot longer than i wanted, but this will prolly be one of the funnest and most unique vehicles many have seen, cuz i believe ill be one of the first ppl to achieve the supercharged version (7MGZE!) in running form
as stated b4, im also moving soon so that may impact progress some, but i accounted for that in my due dates. if anyone has questions, please ask!
and idk if anyone has seen pics at all, and im unsure how to post them up here, but id really like all to see them. ill see if i can get that figured out tonight. anyway, for any followers, keep checking, ill be posting progress soon.
