Old 04-08-2011, 02:23 AM   #1
supraquest
supraquest is on a distinguished road
Default antifreeze problem
Hi guys got a wierd one i have a 88 7mgte with a prob it is fresh rebuilt head all redone block all redone cometic mls head gasket,arp studs,62-1trim turbo only set at low boost 10 psi till motor is broke in. problem is it blows antifreeze out of over flow tank when i get on it a little bit but no over heat or leaks of any sort did leakdown test with no results????
supraquest is offline   Reply With Quote
