Originally Posted by supraquest
Hi guys got a wierd one i have a 88 7mgte with a prob it is fresh rebuilt head all redone block all redone cometic mls head gasket,arp studs,62-1trim turbo only set at low boost 10 psi till motor is broke in. problem is it blows antifreeze out of over flow tank when i get on it a little bit but no over heat or leaks of any sort did leakdown test with no results????
your overflow meter is bad i bet...
mine did that, then finally over heated..
so dont be too hard...til its fixed
