For the AC, check your AC pressure. At rest, the high side and low side should be equalized to over 120 psi. If it doesn't have even 75 psi, the AC compressor will not kick in.
The 'cruise main' switch turns on the cruise control. When the green light is on, the cruise control, operated by three buttons on the lower spoke of the stock steering wheel, should work.
