Originally Posted by Awyman18
but idk if i should get the stock hg because ive heard its alot more forgiving? Instead of a metal one
you don't need a metal HG. not unless your planning on running 30# or more of boost. A larger question you should be asking yourself is do I want bolts vs studs.. bolts are fine and thats what ive used. studs are better but not defiantly needed. just remember to torque them above spec.
