Old 04-10-2011, 11:23 AM   #12
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
  • Al of the cylinders is between 150 and 155psi.
Agreed those numbers are okay, but (fyi) a brand-new 2jz-gte reads about 170psi. I'd suggest you should also do a leakdown test.
  • why do you take the front sway bar off what is the reason
For the best drag race launch, you want the back tires firmly planted, regardless of body twist or suspension travel. When the front sway bar is doing its job forcing the body flat, the rear tires aren't optimally planted.
  • Does a twinscroll turbo make any diffrense on spool up time
Not at all, unless you have one of these:
http://www.spracingonline.com/store/...ool_Valve/3643
Life begins at 30psi.
