Thread: Bubbling Noise
Old 04-15-2011, 12:53 PM   #9
interested!
Hi!
Had the same problem over a few months -- check the overflow bottle for extra water -the cap may be releasing due a VERY small head gasket leak -put the overflow tube from the radiator into water , run the engine and check for bubbles -get those bubbles checked for exhaust gas emissions , mine were positive -had to do a gasket change -then found the head was corroded and needed welding/skimming- seems to be a common problem !-7MGTE .
