Old 04-16-2011, 08:21 AM   #13
87hilux7mge
87hilux7mge's Avatar
if you didnt have your sterio and alarm installed professionally, check your wiring over. if you did, the alarm is most likely the problem for the afor-mentioned problems. alarm systems are tricky, especially if they are straight wired to power and not set as an on demand or with a back up system.
when i had an alarm in my camaro, it had its own proprietary power system (just a small 12v system) that was charged off of the alternator and disconnected from the main power system.
go invest in a volt meter, its well worth the price of 20-30 bux for a craftsman one, im glad i have mine.
