That would be a Hall Effect sensor and yes, I believe so. On the 5spd equipped ECU's I "think" it's just used for cruise control, ABS and might be used as a minor fuel trim modifier.
The oil pressure sensor is used as a critical fuel and timing control. This signal is pretty much static and significantly dampened inside the sensor.
