Originally Posted by mirage83
I've got some serious issues with the cluster in my '88 and could use some help.
The cluster housing has been checked and all continuity checks were good, all the gauges themselves seem to be okay, but the #1 speed sensor, the fuel gauge, and the oil pressure gauge are all non-functional.
Any thoughts or advice will be appreciated.
http://www.cygnusx1.net/Supra/Librar...x?S=Main&P=136
The speedometer has nothing to do with the rest. If your other gauges such as the tach, boost or battery gauge, etc are functioning then the issue is most likely a burnt trace in the flexible circuit on the back of the cluster.
