to get the car on the dyno...depends on the place you go...the typical range is $75-150...maybe more...my friend got his rsx tuned and dynoed for $250.. i think it was a clubsport tune i dont remember...i got mine tuned for about $275, we went to different places, the procedure takes at least 2hrs...to set the process up, get the current map for the car, get the car on teh dyno, make sure all the connections are good, then makin at least one to three good runs, while in between those runs the map is tweaked, though i was able to help tweak the powerband so i could run the car the way i wanted to, thinking about it that i paid all that money and basically tuned it myself with some professional help, while my friend paid that much to get it tuned by a pro...like i said it all depends on where u go, some might be cheaper than others...but they also might be cheaper for a reason like maybe the guy doesnt know wut hes doin...just make sure u ask the right questions and not just...can i use your dyno? or can u tune my car?
Now: Saving for an MKIV
Broken Rides:
