You should use 245/50's on all four, it'll give you better grip. I got kumhos, but hankook has good tires, so does dunlop or toyo, just depends on your price range.
Make sure you replace your bushings also, the rubber goes bad and it makes the car handle very poorly, so get new ones or some poly's.
