Thread: Adjustment?
Old 09-30-2005, 01:08 PM   #2
SupraMan1784
SP58GT
redo the gear timing....u might have to retard it back a couple degrees.. not sure how many, im at work right now so ill try and reply back when i get home, it should do the trick...since i assume u are running the factory timing, the backfire shouldnt have anything to do with the i/c piping or that fact that you did not recirculate the bov, cause all recirculating does is basically reusing the boost u made alrdy...
Now: Saving for an MKIV
Broken Rides:
