well the shifter looks to be in the proper spot. install the shifter and row through the gears, that will tell you if you need to modify the trans tunnel.
the mount, like i said, i cant see clearly, and last time i was under a 7m powered car, i did it all by feel.
id make sure you have a pretty decent mount, cuz one bolt to an ear tab on the tranny doesnt seem like enough.
