You flat out cannot run straight ethanol or E85 in your supra. The best you could do would be to upgrade your injectors for some flowing at least 25% more volume and add a wide band and fuel controller.... then you need to replace all the incompatible parts in the rest of the fuel system (primarily hose and pump).
