Old 04-22-2011, 10:55 PM   #35
rjSupra
rjSupra's Avatar
rjSupra is on a distinguished road
Default Bewildered - problems: boiling coolant at idle now, low power, hard / no start random
7M-GTE stock. AT. 131K. Symptoms:
Very low power since I've owned it. WOT 1.5 years back and the the car would turbo up and pull strong after low power not on the boost. Now, it is much weaker. Sat a lot in 1.5 years.
Recently in 55-65 degree F weather, the car temp shot up in a parking lot (after hwy driving 1.5 hours - but no high temp there except up not steep hill where my turbo boost sat at +4 and I saw the temp go way up).
The coolant makes horrible boiling gurgling noises. Very hot overflow reservoir.
Car idles at 600-650 instantly on start up. IF it starts. Always starts warm, but sometimes won't start no matter what when cold - cranks and cranks.
New batt, new water pump, new T Stat and I clipped toggle and drilled 4mm hole
TPS checks out in spec.
ECT seems to pass all ohm / volt testing correct. Alt working properly.
Each pair of spark leads shows pulse on timing gun. Set timing properly - or nearly to 11 degrees.
Pulled CPS and replaced seal and set correctly with timing gun.
Fuel pump sends fuel with FP - B+ jumped. Can hear whine from pump underneath rear of car too.
Car has sat a lot since 2004/5. Only occasional runs up and down private road. No info on HG / BHG or other issues.
Because it's sat around a lot, and previous owner just added 1-2 gallons of regular gas here and there and drove it 1/4 mile on occasion, I am thinking the fuel filter is clogged?? That's my new theory. I am in hopes it's super clogged and causing this all, the super low power, and the hesitation after trying to drive off normal from a full stop, and even the occasional refusing to start. Anyone want to chime in?
(have not check the AFM, or cold start injector - is that a joke where the access to get at the electrical connector and CSI or I am looking at the wrong thing?)
Thanks!!
88 Supra 7M-GTE Turbo, TEMS, Targa stock
rjSupra is offline   Reply With Quote
