Coil On Plug conversion?
hey all. so i searched this through the site a few times and even google and couldnt really find a whole lot. maybe my search tactics suck? kept getting crap for fords...
as most know ill be running Megasquirt, and i wanted to do away with the plug wires and coil pack for a cleaner setup, plus the advantage of hotter spark to the plugs. anything for bigger and better!
anyway, i couldnt find a whole lot of info about who had the best OEM cop's so, i looked at what other ppl use. lexus, gm and GSXR coils were the favorites. then i found the escort ZX2 board. they use COP's from chrysler. found that the chrysler coils from an intrepid put our 35000 volts each. pretty decent. so i picked up a set from the local pull n save.
i plan on using these in a sequential setup, but if that proves too complicated ill switch to waste spark. should be easy enough to tune for sequential spark.
just wanted to know if anyone else has done a COP conversion?
