Old 04-30-2011, 10:17 AM   #2
ochowdero
Originally Posted by amcutem View Post
Hello evryone.
I was curious how hard would it be to properly turbo my na supra, and also, what parts do I need and around how much will all the parts cost. And most of all, is it even worth it. I bought an 86.5 supra and i want to make it a little faster.
I already have a turbo engine bottomend with pistons, ahduhh, and a turbo exhaust manifold. Obviously, im gna need a turbo. Does anybody have one for sale?
Im also planning to jus rewire the stock wirring harness to work with the turbo ecu. Has anybody done that, and is it difficult? I just need the cam sensor, coil, and ecu right. Also, how well will the turbo run with the stock na fuel mangement, just incase i decide to leave the ignition stock and ecu stock. I do have jacobs Ice pack for 6cylinder engine. What do you guys think.
Also, how much is an after market fuel management?
Any
Advice
Is
Appriciated.
any re wiring to the original wire harness may be very difficult. i wouldnt reccomend doing that.... as for the turbo... its not just plug n play like most people want... you should actually buy a brand new turbo kit from turbonics? its like 600$ or something, thats almost around or cheaper then buying a used one and rebuilding that.. if your going to buy a used one go ahead, but REBUILD IT, even if the seller says its rebuilt..REDO IT! cant stress that enough... i would upgrade the fuel injectors to 550cc and lexus AFM it will compensate for the higher AIR TO FUEL RATIO.. im sure theres more but i really cant think right now..
also the kit is a good idea becuz it comes with all 2.5 - 3.5 piping, bov, and the upgraded IC.. which is definately good for that.
other reasons why you should buy a turbo kit im sure...
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
