I also have an aftermarket header with the o2 sensor in the same location which causes a CEL. Now I don't know if that is your problem but I am going to move the sensor on mine up so it is much closer to the stock location. It seems that just extending the wire can cause problems as well as the temp drop because of the lower location down the pipe.
