i have a few sets of injectors that might work for you.
set of ls1 36#hr injectors w/clips, low Z (off 98 buick regal supercharged motor)
set of injectors from buick pk ave ultra (supercharged) 24#hr with clips
can prolly work up some toyota injector clips too.
i have a set of 5m connecting rods too, id just shot peen them and have them reconditioned, then balance everything. (balancing rod/pistons isnt that hard, and most piston kits are already balanced +/- .5 grams, the crank is the only piece that the machine shop would do, or just have them do it all for like 250-275)
u can use the turbo type piston kits from the 7mge as they are the same bore increments, that would take care of the pistons and rings.
bearings id go with clevite 77's or king/acl.
u can pick up an hks mhg on ebay for 100 delivered, 1.2mm thickness
an f1 racing clutch wouldnt be bad, stage 2 is a carbon disk hd unit, thats what im using and they get decent reviews, mine was 150 shipped.
i have a couple 7m oil pumps, ones a supra style mid sump, the other is a front sump style. ive cleaned them, but havent checked lash. they both were in running motors.
