Originally Posted by 87hilux7mge
get the clutch properly bled then come back and let us know what its doing. improperly bled clutches suck and they make everything feel wrong especially with air in the line.
i was talking to #btwilson and he asked if i bench bled the master cylinder
which i did not do,
the system when i would bleed it would have a full stream come out but for some reason it still happens...
ima bench bleed both my master and slave cylinder to see if that solves it..
i did bleed it properly just didnt know i needed to prime the master cylinder before i hooked it up and bled the system like normal
