Thread
White smoke/air intake problem?
05-12-2011, 07:20 AM
4
Cyberguy1992
just make sure your ignition timing is set correctly.. Also check if you have oil around the spark plugs if you do then u probably need to replace your valve stem seals... Its not hard just time consuming and a bit tedious..
Cyberguy1992
View Public Profile
Send a private message to Cyberguy1992
Find More Posts by Cyberguy1992
