Originally Posted by johnvin
hey guys, i just got my new motor on Monday and i just got her in today took for ever! it was a B**** to get in! had a hard time lining up the motor mount ! and then i had to switch out the incetors because they plugs weren't the right ones  . almost done just have to hook up the trans and the rest of the wires. if you guys have any tips or anything that would help me it would be greatly appreciated ! thanks !!
What motor is it???????? If its a 7mgte, I would go ahead and replace the head gasket with a thicker, metal one. Also check the wiring harness to see if any of the wires are old and brittle, if so you should go ahead and replace the bad wires now instead of down the road after they break.
