Engine Stumbles when accelerating
1986 Automatic
I'm trying to figure out what is causing my engine to stumble.
I have already replaced spark plugs, rotor, distributor cap, wires.
No codes are coming up, TPS, coil are both good. Cleaned throttle body.
I'll just describe how I have been able to recreate the problem:
I'll start the engine (hot or cold), then floor it until I get to about 30 mph (engine runs fine during this part) and then I let off accelerator. Anytime I try to accelerate after that, the engine stumbles and the idle speed is erratic, even stalls sometimes if stopped at a light.
Any help is greatly appreciated! Thank you!
