Originally Posted by Sonyps307
Check for air/vacuum leaks
I forgot to mention that I checked all hoses for leaks. As far as I can tell they are all good. And I had a mechanic verify that they were
They are very small stumbles most of the time. Almost like little 'hiccups' of the engine cutting out.
When it is really bad then it will actually cause it to shift late and hard in addition to the stumbles. The RPMs will just go up to about 4k or 5k before it shifts.
New transmission installed about 3 months ago, this problem has occurred before and after the transmission was replaced
